Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: André Olivera on April 22, 2011, 02:51:41 am
Hi!
Does someone know a way to do an "Make Composite" action in one element?
I found a property of Element ("CompositeDiagram") but it is to get the composite diagram if the element is composite.
I want to know how to turn the element composite, and create this diagram.
Thanks!
André,
There's a whole lot of posts about how to make an element composite on this forum. A search for "composite" should already reveal most posts.
I remember it includes some messing about in the database as this function was not exposed by the API.
IIRC they added that in v9.
An IsComposite attribute has been added to the EA.Element class in Enterprise Architect 9. To set an element as composite, simply set IsComposite = True.
For more information on the EA 9 beta, please see:
http://www.sparxsystems.com/products/betas.html
HTH.
Thanks Geert and Aaron..
Geert:
I found two topics interestings for me in the search:
With this: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1301601786
I understand that I can put a diagram inside the element and after click in the button "create composite" and it will work.
And this: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1302080632
is more similar with what I want to do, but I didnt test yet if works. According the topic I have to create a diagram with the type "CompositeStructure" inside the element.
Aaron:
I think that this solution (create a diagram inside the element) wont turn the element composite. For me it is not a big problem I think. I think that with this attribute it will work fine.
For now I cannot change my version of EA. But I will try make this after.
Thanks a lot!
André.
I tested..
I created a diagram with type "CompositeStructure".
The element didnt change to composite then Im not able to go to the diagram with double-click.
I turn the element into comsposite (Advanced -> Make Composite) then the created diagram is accessed by double-click.
Im almost sure that in version 9, if I change this property by code I can access with double-click.
The topic I was referring to was this one:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1217982429/0
this explains how to make an element composite using the API in EA 8.
I haven't tested the functionality in v9 yet.
Great!
According the topic I can change some fields in the database (.EAP) to turn the element composite.
I will try to use the method "Repository.SQLQuery (string SQL)" to do this.
I dont know why my search didnt return this topic. Now I am having a lot of problems with the search in the forum.
Thanks a lot!
André,
Repository.SQLQuery won't work if you are trying to update something.
You'll have to use Repository.Execute(SQLString). (undocumented backdoor operation :o)
hehe great..
I read this in the other topic but I thought that they were talking about this function (SQLQuer())..
really crazy this function without anyone documentation.. but is ok!
thank you!
