Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Ted Speers on September 27, 2016, 01:34:33 pm
Title: adding attributes in profiles
Post by: Ted Speers on September 27, 2016, 01:34:33 pm
I want to create a class stereotytpe that when I pull it into a diagram, it has the attributes and methods already attached.  The documentation only shows how to add tags to a  stereotype (I have no idea what good tags are BTW ... would love to be enlightened).
The behaviour i want is found in the ArcGIS toolkit .
When a <<CodedValueDomain>> is added to a diagram, it has attributes ... 3 of which have nothing to do with the Profile.
Title: Re: adding attributes in profiles
Post by: KP on September 27, 2016, 02:02:19 pm
The way I would do this, and the way it has been implemented in ArcGIS, is as follows:
Instructions for each step can be found in the help file. Good luck!
Post by: Ted Speers on September 28, 2016, 12:09:01 pm
thanks ... it wasn't obvious
Post by: Paolo F Cantoni on September 28, 2016, 04:41:39 pm
Hi Ted,
When you get it working, can you post the relevant snippet(s) of the MDG?  I'm interested in seeing the effects of the process on the output MDG.
TIA,
Post by: Ted Speers on October 03, 2016, 06:13:21 am
Just got around to it and haven't been able to get it working.
When I drag the pattern onto the diagram, it says 'Pattern not found in model's resources.'
I am definitely including the pattern in the MDG build wizard.
In the toolbox ... I'm naming the attribute TechName::PatternName(UMLPatternSilent) where
- TechName is the name I enter in the first line "Technology" in the MDG wizard and
- PatternName is what i call the pattern in the save as  UML pattern dialog.
BTW, if i right click on 'Pattern' in the model resources box, i do not get an option to import a pattern.  I don't think importing is necessary if it is included in the MDG build dialog.
Using EA v11
Post by: Geert Bellekens on October 03, 2016, 07:27:26 pm
Patterns are NOT included in the MDG file (unfortunately) and have to be distributed separately.
There's a discussion from a few months ago about this specific shortcoming of MDG's
Post by: Ted Speers on October 04, 2016, 12:10:56 am
Can you tell me how to modify the procedure supplied earlier in this thread?  Does the fact that I can't appear to import patterns cause an issue?
<copied from above>
Create a profile with your stereotype. Save it.
Create an MDG Technology that includes your profile. Let the Technology Wizard create a .MTS file so you can rebuild the technology later.
Deploy the MDG Technology.
Create a stereotyped element on a diagram. Give it all the attributes and operations you want it to be created with.
Save the diagram as a Pattern.
Create a toolbox profile. One of the toolbox commands will be "MyTechnology::MyPattern(UMLPatternSilent)". Save the toolbox profile.
Rebuild your technology, including the Pattern and the Toolbox Profile.
Re-deploy your technology.
Post by: Geert Bellekens on October 04, 2016, 12:29:59 am
Ted, the "redeploy your technology" step has to include distributing your pattern xmi to a specific location (I don't remember exactly where)
Post by: Ted Speers on October 04, 2016, 03:24:20 am
so this thread ( http://sparxsystems.com/forums/smf/index.php/topic,30878.msg224230.html#msg224230 ) refers to putting stuff in this directory ... C:\Program Files (x86)\Sparx Systems\EA\ModelPatterns
will give that a try
Post by: Ted Speers on October 04, 2016, 06:05:22 am
didn't work
Post by: qwerty on October 04, 2016, 06:45:24 am
I know this does not sound quite helpful, but sleeping a night over it did solve such issues for me in most cases. Usually it was a simple typo or I saved the wrong date in the wrong place (double the error!). Yes, EA is very unforgiving when it comes to errors in MDG creation. You just get a "does not work" and no hint what might be wrong. If sleeping over it did not solve it, start over with a tiny sample and grow that stepwise (!) until it has everything you need.
Post by: Ted Speers on October 04, 2016, 02:24:11 pm
haven't quite slept on it ... did inspect the .xml file generated by the wizard ... i'd attach it if i could
in the xml the data structure is
<UMLPatterrns>
    <UMLPattern>
    ---- from the pattern file ...named after the drawing
    </UMLPattern>
    <UMLPattern>
    ---- from the MDG generation wizard ... name = MyName
    </UMLPattern>
</UMLPatterns>
in the toolbox, i tried both names ... drawing name in first UMLPattern tag and name in second tag ... both give same error when i drag it from toolbox onto a drawing.
Post by: KP on October 04, 2016, 02:38:11 pm
It's the technology ID, not name. The second line of your technology will be something like this:
  <Documentation id="GoF" name="Gang of Four Patterns" version="2" notes="Use patterns from the book Design Patterns by Gamma, Helm, Johnson and Vlissides." infoURI="http://www.sparxsystems.com" supportURI="[email protected]"/>
In this case, it will be "GoF" that you need to use, not "Gang of Four Patterns".
Post by: Ted Speers on October 05, 2016, 01:28:09 am
that works, thanks
Post by: Paolo F Cantoni on October 05, 2016, 10:34:35 am
that works, thanks
Hi Ted,
That's great!  Just so there's no confusion, can you post a snippet?
TIA,
Post by: KP on October 05, 2016, 10:42:14 am
that works, thanks
Hi Ted,
TIA,
Until Ted gets back to you, have a look at C:\Program Files (x86)\Sparx Systems\EA\MDGTechnologies\GoF.xml - it's a technology containing nothing but patterns and toolboxes.
Post by: Paolo F Cantoni on October 05, 2016, 10:49:27 am
Thanks KP,
I'm not ready to "pull the trigger" just yet, but soon.
Post by: Ted Speers on October 06, 2016, 01:27:22 am
Don't know how to send attachment or paste XML into this tool.
<?xml version="1.0"?>
-<MDG.Technology version="1.0"><Documentation version="0" notes="RISC-V" name="RISC-V" id="RISC-V"/>-<UMLProfiles>+<UMLProfile profiletype="uml2">---------------</UMLProfiles>-<UMLPatterns>-<UMLPattern>-<XMI timestamp="2016-10-03 20:13:08" xmlns:UML="omg.org/UML1.3" xmi.version="1.1">+<XMI.header>--<XMI.content>-<UML:Model name="EA Model" xmi.id="MX_EAID_EB91BB1F_965E_4180_96B6_983A85D53E0A">-<UML:Namespace.ownedElement>-<UML:Class name="R-Type" xmi.id="EAID_92E22597_1970_4db6_903D_5D49EDABABE0" isActive="false" isAbstract="false" isLeaf="false" isRoot="false" namespace="EAPK_EB91BB1F_965E_4180_96B6_983A85D53E0A" visibility="public">-<UML:ModelElement.stereotype><UML:Stereotype name="Instruction"/></UML:ModelElement.stereotype>+<UML:ModelElement.taggedValue>+<UML:Classifier.feature>-----------------------</UML:Class></UML:Namespace.ownedElement></UML:Model><UML:TaggedValue xmi.id="EAID_5870EE46_4501_f145_B554_C49465EDD7A2" tag="Function" modelElement="EAID_92E22597_1970_4db6_903D_5D49EDABABE0"/><UML:TaggedValue value="R-type#NOTES#Values: R-type,I-type,S-type,SB-type,U-type,UJ-type " xmi.id="EAID_81FBE1CB_0A26_730a_934D_F9E4C1591F9C" tag="Instruction Format" modelElement="EAID_92E22597_1970_4db6_903D_5D49EDABABE0"/><UML:TaggedValue xmi.id="EAID_18F47F6E_2E49_a72e_A4AF_23A437402F50" tag="InstructionSet" modelElement="EAID_92E22597_1970_4db6_903D_5D49EDABABE0"/><UML:TaggedValue xmi.id="EAID_034EE602_51FD_c451_9E84_7890EDF68DC5" tag="Length" modelElement="EAID_92E22597_1970_4db6_903D_5D49EDABABE0"/><UML:TaggedValue xmi.id="EAID_0B0F853A_6515_7365_B239_5CC84651A175" tag="OpCode" modelElement="EAID_92E22597_1970_4db6_903D_5D49EDABABE0"/>-<UML:Diagram name="RISC-V MDG" xmi.id="EAID_5AE55109_A5EE_4aa0_85B8_139C76326F32" toolName="Enterprise Architect 2.5" owner="EAPK_5AE55109_A5EE_4aa0_85B8_139C76326F32" diagramType="ClassDiagram">+<UML:ModelElement.taggedValue>-<UML:Diagram.element><UML:DiagramElement style="HideIcon=0;DUID=6A3DF6E5;ImageID=0;" seqno="1" subject="EAID_92E22597_1970_4db6_903D_5D49EDABABE0" geometry="Left=470;Top=159;Right=672;Bottom=299;imgL=5;imgT=5;imgR=207;imgB=145;"/></UML:Diagram.element></UML:Diagram></XMI.content><XMI.difference/>+<XMI.extensions xmi.extender="Enterprise Architect 2.5">--</XMI></UMLPattern></UMLPatterns>-<UIToolboxes>-<UMLProfile profiletype="uml2"><Documentation version="1.0" notes="RISC_V_Toolbox" name="RISC_V_Toolbox" id="45E1CDED-3"/>-<Content>-<Stereotypes>-<Stereotype notes="" name="RISC-V Elements" hideicon="0" borderwidth="-1" bordercolor="-1" fontcolor="-1" bgcolor="-1" cy="70" cx="306">+<AppliesTo>--<TaggedValues><Tag name="RISC_V_Primitives::Instruction(UML::Class)" type="int" default="Instruction" values="" unit="" description=""/><Tag name="RISC-V::RISC-V(UMLPatternSilent)" type="int" default="R-Type" values="" unit="" description=""/></TaggedValues></Stereotype></Stereotypes><TaggedValueTypes/></Content></UMLProfile></UIToolboxes></MDG.Technology>
Post by: Paolo F Cantoni on October 06, 2016, 11:03:13 am
Thanks for that Ted,
I popped it into an XML parser and it complained.  This version seems to have the correct syntax.  You may wish to "compare and contrast".  I haven't had a close look, so I can't comment on the content.
<UMLProfiles>
<UMLProfile profiletype="uml2"/>
</UMLProfiles>
<UMLPatterns>
<UMLPattern>
<XMI.header>
<XMI.content>
<UML:ModelElement.taggedValue/>
<UML:Classifier.feature/>
</UML:Class>
</UML:Model>
</UML:Diagram>
</XMI.content>
<XMI.difference/>
<XMI.extensions xmi.extender="Enterprise Architect 2.5"/>
</XMI.header>
</XMI>
</UMLPattern>
</UMLPatterns>
<UIToolboxes>
<Content>
<Stereotypes>
<AppliesTo>
<TaggedValues>
</TaggedValues>
</AppliesTo>
</Stereotype>
</Stereotypes>
<TaggedValueTypes/>
</Content>
</UMLProfile>
</UIToolboxes>
</MDG.Technology>
