Enterprise Architect => Bugs and Issues => Topic started by: Jens Nötzold on November 03, 2016, 09:14:29 pm
I get an error
DAO.Database [3464] Data type mismatch in criteria expression
when setting up an element filter on RTF template document options to render
- only elements having tests of testclass one of 1,2,3,4,5
- and only element test of testclass one of 1,2,3,4,5
(otherway : want to exclude elements without tests or testclass = 6)
Setting up a filter criteria on t_objecttests.testclass is not working,
- neither from Document Options->Element Filters
- nor from Document Options->Other Filters
- nor from Find in Project->Query Builder
None of the operators EqualTo, Not Equals, One Of can be used, no chance for the user to input the correct type to avoid the problem!
The error persists in EA 12.0.1212, 12.1.1229, 13.0.1306
Its a very frustrating one as it prevents us from running test reports!
Any help on this is welcome to get around this.
Cheers,
Jens Nötzold
Update:
Sparx support says:
"This has been confirmed by hte devlopers and will be fixed in a future
build of EA.
As a workaround you could create a Custom SQL Fragment template for this
purpose."
