Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: adepreter on August 15, 2011, 09:45:44 pm
Does anybody know how to disable Shape Scripts based on some diagram property or custom tag?
Basic Requirement
- Context: a specific diagram
- Default behavior: Shapes are rendered following shape scripts associated with stereotypes.
- Alternative behavior (when a diagram property or custom tag is set to X): Default shape rendering is applied; Shape scripts are ignored
Solutions that we are trying to select custom or default shape rendering in a diagram
1. Use existing diagram option in the core Sparx product
Problem: Option not found; no documentation found
2. Access existing diagram properties from Shape Script
Problem: How to access current diagram properties in a Shape Script? No documentation found
3. Define custom diagram tags and access these from Shape Scripts
Problem: No documentation found
Alain
There is a shape script command: drawNativeShape()
On this page (http://www.sparxsystems.com/enterprise_architect_user_guide/9.0/standard_uml_models/displaying_element_properties.html) there is a list of properties you can test against in shape scripts. Look at those beginning "diagram."
Good. So I will set a stereotype value on the diagram and access the value in the Shape Script to decide about what is to be displayed.
Thank you for the useful input.
Alain
