Enterprise Architect => General Board => Topic started by: Screwtape on January 11, 2017, 08:21:46 pm
Hi!
I've just tried to update the gateway direction BPMN parameter, on a BPMN gateway, and I can't see how to set the parameter. The parameters are displayed in the BPMN tab, but it does not allow me to update them.
Can anyone suggest what am I doing wrong?
Thanks!
Screwtape.
Do you have security on your model ? It could be that the diagram is locked or you don't have permission to edit ...
Hi!
I don't have any security enabled as far as I know, as I'm using a local repository.
Thanks!
Screwtape.
I just replicated the symptoms you've described by locking the element. (Select the gateway, right-click, lock element). Having done that I can still change the properties on the "Main" tab, but they are greyed out on the BPMN tab. If I unlock the element, I can once again set the gateway direction.
You can tell if an element is locked in the project browser because it will have a red exclamation mark next to it.
