Enterprise Architect => General Board => Topic started by: tzafrir on January 24, 2017, 06:22:49 am
Is there an API that can do a direct update on data on DB?
Repository.Execute
You should not use it except you like juggling with bombshells.
Repository.Execute
I must like juggling with bombshells then :P
No, in all seriousness, you should only ever use it if there is no viable alternative. But there are a number of cases where I had to use this as a last resort, either because the thing I was looking for wasn't exposed in the API, or in cases of mass updates where using the API would mean hours of runtime against half a second when using a direct SQL update statement.
Refer this
http://sparxsystems.com/forums/smf/index.php/topic,26576.msg207074.html#msg207074
Hope this helps
BR
Nabil
Thanks all,
I need it for the following case:
When entering notes in Hebrew
The API of notes will return the value:
Notes + DB = "מודל ה"
And it put the value Left To Right
When using CtrlShift it does move it to the right and change the DB as follows:
<p align="right" dir="rtl"><span dir="rtl">מודל</span><span dir="rtl">ה</span></p>
Do you think there is other way besides intervention with an update statement to get that result without manual touch?
Sorry, but I can't follow your steps. What does Ctrl-Shift do? And what is "it" doing the RTL? Maybe you list the steps in some order one can follow?
If you are assigning to the notes, just wrap any paragraphs you want right to left with <p align="right" dir="rtl"><span dir="rtl"> and </span></p>.
If you can construct that string it's no harder to assign it using the API than through SQL.
