Enterprise Architect => General Board => Topic started by: deadbird on January 31, 2017, 04:15:15 am
Title: View roles notes in organizational chart
Post by: deadbird on January 31, 2017, 04:15:15 am
Hi everyone.
I'd like to view roles notes within an organizational chart (see: http://www.sparxsystems.com/enterprise_architect_user_guide/12.1/business_engineering/org_chart.html (http://www.sparxsystems.com/enterprise_architect_user_guide/12.1/business_engineering/org_chart.html)).
When I try to activate it from "Properties" > "Elements", nothing changes  :(
Can someone help?
Title: Re: View roles notes in organizational chart
Post by: Nabil on January 31, 2017, 03:59:34 pm
What are you trying to modify here?
To modify the name of elements when you drag and drop the pattern to diagram.
Uncheck the the option "Use Auto Names" Then try to rename elements.
Once the diagram is created then you can modify/add notes for each roles.
BR,
Nabil
Post by: deadbird on January 31, 2017, 06:18:18 pm
No, what I'm trying to do is make the Role notes visible within an organizational chart.
Most diagrams offer this feature (UML diagrams for instance), a few don't.
Post by: Nabil on January 31, 2017, 10:33:38 pm
Correct me If I'm wrong. What you mean is the element notes are not visible in the diagram? Am I right?
Yes it is not showing the roles notes on diagram because of its stereotype. If you remove the stereotype "OC_Role. Then it will display the notes.
BR,
Nabil
Post by: deadbird on February 03, 2017, 01:15:28 am
Yes, you are.
Removing the stereotype has no effect on note display :(
Post by: Nabil on February 03, 2017, 04:21:09 pm
Not sure what went wrong. I tried this in EA 13 it worked when i removed the stereotype.
BR,
Nabil
