Enterprise Architect => Bugs and Issues => Topic started by: reherz on February 10, 2017, 10:59:19 pm
Title: Tagged Value wrong Values
Post by: reherz on February 10, 2017, 10:59:19 pm
i have two different customized Tagged Value Fields of Type Decimal and Problems with the Data in both fields
--> While editing and reading information in Element Properties / Tagged Values the value of the field is "0,0" (or a different value)
--> requesting the value via SQL or in Generated Documents the value changes to e.g. "1,9853888367081E-120"
Why are there two different values? How can I request the right value?
Bizarrely not all values are different, some values are the same in both requesting ways.
Thanks!
- I'm using EA 12.1 -
Title: Re: Tagged Value wrong Values
Post by: qwerty on February 10, 2017, 11:08:45 pm
That's the nature of floats in a digital world. For all A, B element R: identity is defined if abs(A-B) < epsilon. And 1E-120 looks very close to that epsilon.
Post by: VKN on February 13, 2017, 09:56:10 am
As a workaround, you can change your system's decimal separator to a period (.)
