Enterprise Architect => Suggestions and Requests => Topic started by: Viking on February 16, 2017, 02:13:35 am
(1) does anybody know how to find out the mdgtype of a diagram (without db-query)?
(2) does anybody know how to find out the metaclass of a element (without db-query)t?
(3) could some point me to a description of base clase (see UML types. Not the base class for inheritance)?
Many thanks in advance, V.
Scripting. Try inspecting the EA.Diagram.MetaType value
Scripting. Try inspecting the EA.Element.MetaType value
Sorry, don't understand the question.
Many thanks.
Wouldn't it be helpful showing these information ([1] and [2]) in the properties-sheet?
To [3]: with base-class I am talking about Project > Settings > UML types (the term base class in the document is also used for decribing inheritance. Or does base class for Sterotypes has something to doe with inheritance?).
Hi Viking,
If you are talking about the "base class" in the stereotype page of the UML types dialog, it is misnamed. It should be captioned: "Metaclass to which to apply this stereotype". You can define more than one stereotype with the same name and apply each to a different metaclass. You may even note that you can apply it to "<All>", but not to "<Shapes>" or "<Lines>".
I don't believe it has anything (directly) to do with inheritance - since you can apply the "<All>" value.
Hi Viking,
Hi Paolo, thank you very much.
For my opinion the manuals are to short for this domain.
V
