Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: babdev on July 07, 2017, 12:20:48 am
Hi
After creating a new model using the Basic Template in MDG Technology Builder I'm trying to generate the profile XML files. The examples say to "Export your Profile by right-clicking the parent Package of this Diagram in the Project Browser and select 'Save Package as UML Profile...'" but I can't find this option in EA13. I've found it in EA12, under the Advanced... option. Does anyone know where to find it in EA13 or is there a different way of doing it?
In my build 1350) it is still just in the context menu under Advanced (ast item)
We're using build 1307, wonder if it's a bug that was fixed in later builds. Can't find the release notes for v13 builds to check :(
I also used former 13xx builds, but I cannot remember if I did generate profiles with 1307.
Anyhow, if it is not there in 1307 it is certainly a bug. Maybe you try 1310.
Could be that you're missing a permission, perhaps?
You can also create a profile by right-clicking in the diagram. The two methods give different results. :)
/Uffe
Or it could be a missing menu command. Check the infamous View|Menus and Commands (or whatever is it called now) and make sure you set your menu set to "complete"
That's it! Thanks Geert, would never have found that. :)
