Enterprise Architect => Bugs and Issues => Topic started by: Bebert on October 09, 2017, 11:29:24 pm
My main file is 0 ko size. EA can't open anymore. Obviously it 's empty.
I don't understand why EA clears my file. How it's possible.
I use EA13.5
BR
I've never seen or heard anything like that, so it seems unlikely to me that EA is the culprit.
But with a case like this I would contact Sparx support. Maybe they can shed some light on this.
I don't think however they can magically bring back your model, so I hope you still have a backup.
The other problem : our backup logs see only modification on the ldb file no on the eap. that's mean I don't have recent back up. the last one is on july. Why in july I don't know.
You only recognize that your backups did not work when you need them.
Not really, the behavior of the .eap is odd.
I thought It was the backup but it works fine with all the files .ldp included.
I could provide the backup log to the EA team.
eap files in fact are MS Access mdb files.
So, more or less what .doc is/was for Word.
So if you have lost this file you have lost your model.
The .ldb is a MS Access temporary file that exist if a mdb/eap is open only. For you as a user it is more or less useless. To see what .ldb is intended for, see here:
https://support.microsoft.com/en-us/help/966848/what-is-an-ldb-file
If your eap has size 0, nothing but a backup could help you.
I personally have never seen such a problem and I would assume it has something to do with your environment rather than with MS Access or EA on top of it.
You can contact Sparx per mail, but a 0k EAP simply means you got nothing. EAP == MDB (or whatever that suffix was for Mickeysoft Access). What Peter said...
EA doesn't empty your file by itself.
Looks like your model has been moved/deleted and a new model is created through the Windows folder (New | Enterprise Architect Model) which currently creates an .eap with a size of 0 (Sparx is aware of this).
Check the Date created flag.
To clarify VKN's response.
We currently know of only one scenario that can cause a 0 byte eap file. That is, the Windows Shell 'New' command creates an empty file without asking Enterprise Architect to fill it.
Unfortunately, by definition, the presence of a 0 byte file delivers no information about why it is 0 bytes. If you describe your processes that may suggest additional possibilities for the cause.
That's not true, it tells you it's not an event that creates the database schema. The file also has all the normal file system meta-data attached to it which tells you who and when it was created.
So as you have indicated the how, the OP just has to look at the meta-data to find out the who and then when. Once they know the who they can ask them why.
That's quite a long way forward in clearing up the mystery.
(argumentum ad ignorantiam)
[SNIP]
And it's Friday the 13th!
Not being picky but just ignorant: where does Windoze store the creator in file attributes? I can only see Size, Created/Modified/Accessed and R/W.
My crystal ball doesn't tell me what version of Windows you're using or which of the approximately 5 local file systems it supports. Or if you're looking at a network drive how good the underlying implementation of CIFS is :-)
But in general some metadata will be in the Master File Table (MFT), some will be in meta-files and some in Alternate Data Streams (forks).
What you see depends on the exact file system, and Windows, OSX, and *NIX all implement the same concepts in different ways.
Me still thinking that NTFS is Mickeysoft's ultima ratio.
(This is probably a furphy, but anyway.)
I recall that about a million years ago there used to be a problem with the Jet engine when the MDB file was stored on a network drive. I did a bit of a search through the forum but cannot find anything apropos. All I really can remember is that one symptom was "suddenly" empty mdb files. It was not an EA problem, as I said it was something about the Jet engine.
Anyway I would presume that by now that issue would have been resolved, so this is probably a furphy.
b
I wouldn't be surprised if that was still an issue. MDB files are generally excluded in all of Microsoft's replication mechanisms like Offline files for exactly this reason.
