Enterprise Architect => General Board => Topic started by: rupertkiwi on May 02, 2018, 12:21:25 pm
Is it possible to restrict specific scripts based on which group a user belongs to?
In a similar way that diagrams or packages can be locked depending on which group a user is a member of?
I can restrict the running and editing of all scripts based on a user's group via the Security Group settings but it would be good to restrict individual scripts
Rupert
Hi Rupert,
Not out of the box, but you can of course test the current user in your script yourself, and refuse to execute if she doesn't meet your requirements.
OK, thanks Geert for your prompt reply.
I will have a play around and see how I go
Cheers,
Rupert
Use the following function in JScript-type script and validate it in the logic of your script:
function isUserInGroup(groupGUID) {
var userGUID = Repository.GetCurrentLoginUser(true);
var result = DBGetFieldValueArrayString("GroupID", "t_secusergroup", "UserID = '" + userGUID + "' AND GroupID = '" + groupGUID + "'");
if(result.length == 0) {
return false;
return true;
