Enterprise Architect => General Board => Topic started by: kimballjohnson on June 08, 2018, 07:05:02 am
Title: 'usys_system' value in EASchema_1220_SQLServer_Update1.sql causes error
Post by: kimballjohnson on June 08, 2018, 07:05:02 am
I'm guessing that nobody uses this update script, or if they do, they get this error and give up. Although there is one unanswered post about this if you search for 'usys_system'.
If you run this update script without previously the 'regular' sql schema script, you get an 'unknown object' type of error.
If you run the normal schema script and then run the update script, the error says that 'usys_system' is an error because it is a 'table type'.
If this ever gets fixed it will be because someone cares about this.
