Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Jezvon on July 20, 2018, 06:14:34 pm
I have a query that joins 3 tables and I am trying to retrieve a conditional set of rows depending on whether the record exists in the third table.
If there is a match in the 3rd table then I just want the matching records from the 1st table. if there isn't a match from the 3rd table then I just want one record from the first table.
select o.Object_ID,
reqCon.Connector_ID,
req.Object_ID as Requirement_ID
from t_object o
left join t_connector reqCon on reqCon.End_Object_ID = o.Object_ID and reqCon.Stereotype = 'deriveReqt'
left join t_object req on reqCon.Start_Object_ID = req.Object_ID and req.Stereotype = 'functionalRequirement'
This produces the following type of result, but the ones highlight with the > ... < are the actual rows that are required.
Object_ID | Connector_ID | Requirement_ID |
40936 | 43259 | |
40936 | 43260 | |
>40936 | 43299 | 38013< |
40943 | 43264 | |
40943 | 43265 | |
>40943 | 43298 | 38014< |
>44088 | 46245< | |
44088 | 46246 | |
>42669 | 44655< | |
42669 | 44656 | |
>42670 | 44657< | |
42670 | 44658 | |
You should ask that on StackOverflow since it's a SQL question and not an EA specific.
Replace left join with inner join.
Answered here on StackOverflow (https://stackoverflow.com/questions/51455691/sql-query-to-conditionally-select-a-row-from-a-table-depending-on-join-existence)
