Enterprise Architect => Bugs and Issues => Topic started by: cryptology on August 19, 2018, 11:05:17 pm
I wonder if there is a straightforward way to lock the aspect ratio of an image element when resizing it. I've checked the manual but so far the only way I found to achieve this is by counting pixels in the status bar.
AFAIK this can only be done in a shape script by setting fixedAspectRatio.
If you are after a pasted image in diagrams, change its size with pressing SHIFT key.
It is the same as autoshapes in Excel, Word, etc.
edit\
Well...found the solution.
I had some other commands befor "fixedAspectRatio = "true";".
In the Guide it is written that it should be befor drawing commands. Thats why it didn't work in the first place.
\edit
For Images pressing SHIFT works, thank you for that!
In shape script I can not make it work.
From the MDG Guide I assume that it should look like this:
shape main
DrawNativeShape();
Am I right or is there something I got wrong.
Kind Regards
(I know I could open a new topic but I think it is usefull to have the solution here)
