Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Steve Wartik on February 28, 2012, 08:47:23 am
I've written some JScript code. I'd like the user to be able execute it through a menu. Specifically, I'd like to add a menu hierarchy to Extensions. Just like the ODM-related menu items, a script would be executed each time the user selects an item. Can someone tell me how to do this? Thanks.
I would make an add-in.
See Tutorial: Create your first C# Enterprise Architect addin in 10 minutes (http://geertbellekens.wordpress.com/2011/01/29/tutorial-create-your-first-c-enterprise-architect-addin-in-10-minutes/)
Geert,
An add-in is certainly a possibility, but I was hoping to package and distribute the capability I've developed using MDG. In other words, I'd like a user to select the Tools>MDG Technology Import item, load the file I'm distributing, then see my menus. I would prefer that the user not have to install an add-in too. Is that feasible?
Steve
I don't know.
I've never used MDG before.
Unfortunately, you can't add scripts from your technology into that menu. ODM has been explicitly added by Sparx.
Simon,
Thanks for the definitive response. Obviously not what I wanted to hear. Can I write an add-in that invokes JScript?
Steve
for which reason?
you can create an addin which does exactly the stuff you need.
no need for jscript.
Well, the immediate reasons are: 1) I already have the JScript working; 2) I've never programmed in C#, I dislike Visual Basic, etc. In other words, I'm guessing that making use of my existing scripts would be quickest.
If you programmed in java you wont have any problems using C#
(i for myself started to develop an EA Addin withouth any C# experiences and it never was a problem)
If the jscripts dont do what they should i dont see any other possibilities than start a C# addin.
Its worth a try.
Stao,
Okay, I'll give it a try. I hope you're right about Jave -> C#. Wish me luck!
