Enterprise Architect => General Board => Topic started by: sbleden on September 10, 2018, 11:23:49 pm
Hey Guys,
i just wondering if its possible to create a replica of an existing Design Master via the Command Line?
Greetings
Bastian
Bastian,
Stop right now and find an alternative for the replica mechanism.
This MS Access mechanism is shaky at best and it will come back to bite you sooner or later.
I'd say: more sooner than later.
However, if you're sticky to that Mickeysoft stuff just go and google for "MS Access replica" since EAP is just that.
Hey,
thx for the answers.
Is there another way, the work offline on the same eap file and merge it later?
Greetings
sbleden
Hey,
Greetings
sbleden
Hi, you can't really merge models, but you can use version control to work together in offline mode.
The difference is that you check-out a package for exclusive use. Until the package is checked in again, other people won't be able to edit that package.
You can connect a bunch of different version control systems, but the most common ones are SVN and TFS.
