Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Diëgo on March 10, 2012, 03:29:45 am
I've just spent half a day trying to dynamically create hyperlinks on a diagram.
I've succeeded to create a hyperlink to a package:
var newel as EA.Element;
newel = thePackage.Elements.AddNew("$package://{555834AE-3C56-4860-AEDA-16DF8592A50F}", "Text");
newel.Update();
newel.Subtype = 19; // This one is important for hyperlinks to packages!!
newel.Update();
newel.Notes = "NEW LINK";
newel.Update();
AddElementToDiagram(newel, theDiagram);
newel.Update();
with the AddElementToDiagram function being this:
function AddElementToDiagram(theElement, theDiagram)
var diagramObjects as EA.Collection;
var obj as EA.DiagramObject;
theDiagram.Update()
diagramObjects = theDiagram.DiagramObjects;
obj = diagramObjects.AddNew( "l=200;r=400;t=200;b=400;", "" );
obj.ElementID( theElement.ElementID );
obj.Update();
obj.Style = "BackColor=-1;BorderColor=-1;BorderWidth=-1;FontColor=-1;VSwimLanes=1;HSwimLanes=1;BorderStyle=0;" ;
obj.Update();
Session.Output("Added object " + theElement.Name)
I can't really explain the magic number 19 for subtype, but I've got it from the XMI export.
I did not however succeed to create a hyperlink to a diagram. There's only a few differences from what I've done in the code above:
newel = thePackage.Elements.AddNew("$diagram://{9F181280-8ECF-4bcd-9C28-4A3B138BC68C}", "Text");
newel.Update();
newel.Subtype = 0; // This one is for hyperlinks diagram to diagrams.
I get something on my diagram, but it doesn't work. If I compare the XMI export for my generated link and a manually added link, I see that seem to miss a tag called 'diagram' which holds the GUID of the diagram I'm referring to once more. I can't find it back in the scripting object howerver (I've traced almost the entire object).
<UML:TaggedValue tag="diagram" value="EAID_9F181280_8ECF_4bcd_9C28_4A3B138BC68C"/>
Is there anyone who has ever succesfully added hyperlinks to diagrams and who can explain to me how I should do it? Or someone who can tell me what I'm missing?
Thanks in advance and have a nice weekend,
Diego
Hey there,
as I've been looking all over the place for a solution to create links to diagrams on an existing diagram, and only kept being pointed to this (unsanswered) post, I thought I'd actually post the solution when I found it.. And I did!
First things first: Diego's script actually *does* make a hyperlink. If you click it, the diagram gets selected in the project browser. However, what he wanted to achieve, is to make a diagram hyperlink that actually opens the diagram. The solution below manages to do so.
Analysis steps
- Create a Diagram hyperlink manually by dragging the target diagram onto the diagram and selecting "Drop As..." -> Hyperlink.
- Find the element ID of the created link
var diagram as EA.Diagram; // Set diagram to your current diagram
var diagramObject as EA.DiagramObject;
var element as EA.Element;
for (var index = 0; var index < diagram.DiagramObjects.Count; index++) {
diagramObject = diagram.DiagramObjects.GetAt(index);
element = Repository.GetElementByID(diagramObject.ElementID);
Session.Output("Element: " + element.ElementID);
- Analyse the element in the database
select * from t_object where object_id = '<insert ElementID here>'
Solution
What I found out, was that the Text element actually isn't a hyperlink (so setting the Subtype is not a good idea). It's a "normal" text element, but it has PDATA1 set to the DiagramID. I tried to set PDATA1 via script (some property?), but haven't yet found a "non-SQL" way of doing so. So here's the solution with a little bit of SQL to update PDATA1 at the end.. (If I find out how to get it done without SQL I will post it)
* Creates a link to a target diagram on a diagram.
* @param package Package where the source diagram is located.
* @param diagram Source diagram onto which the link is created.
* @param targetDiagram Target diagram for which the link that is creatde points.
function createDiagramHyperlink(package, diagram, targetDiagram) {
// Make a hyperlink element
var hyperlink as EA.Element;
hyperlink = package.Elements.AddNew(targetDiagram.Name, "Text" );
hyperlink.Notes = targetDiagram.Name;
hyperlink.Update();
// Add the hyperlink to the diagram
diagramObject = diagram.DiagramObjects.AddNew("", "" );
diagramObject.ElementID = hyperlink.ElementID;
diagramObject.Update();
diagram.Update();
// Update the PDATA1 and set it to the target diagram's ID
Repository.Execute( "UPDATE t_object SET PDATA1='" + targetDiagram.DiagramID + "' where object_ID = '" + hyperlink.ElementID + "'" );
I hope this solution is useful to someone out there, even if it is an old post :-). Errors and ommissions excepted.
Cheers,
JDT
<snip>.. (If I find out how to get it done without SQL I will post it)<snip>
You can't update PDATA fields (Miscdata) from the API.
Hey Guys, this thread really helped me to get scripting hyperlinks to point to a different sequence diagram to work. Thank you all. Hope this snippet helps someone out a bit.
hyperlink = srcDiagPackage.Elements.AddNew("$diagram://"+diagram.DiagramGUID,"Text");
hyperlink.Subtype = 0; // This one is important for hyperlinks to diagrams to work!!
hyperlink.Update();
// Required Update the PDATA1 and set it to the target diagram's ID
Repository.Execute( "UPDATE t_object SET PDATA1='" + diagram.DiagramID + "' where object_ID = " + hyperlink.ElementID + "" );
diagramObject = sourceDiagram.DiagramObjects.AddNew("","");
if (con.EndPointX <= con.StartPointX) {
// Connector End Point id <--- Place Hyper link to the left
diagramObject.left = con.EndPointX-35;
diagramObject.top = con.EndPointY+10;
diagramObject.right = con.EndPointX-15;
diagramObject.bottom = con.EndPointY-10;
diagramObject.Sequence=50;
else if (con.EndPointX > con.StartPointX) {
// Connector End Point id ---> Place Hyper link to the right
diagramObject.left = con.EndPointX+15;
diagramObject.right = con.EndPointX+35;
//diagramObject.ElementDisplayMode = templateElement.ElementDisplayMode;
//diagramObject.Style = templateElement.Style;
sourceDiagram.Update();
Hi All,
Thank You for this topic, It helped me to put the 'Package Hyperlink' on current diagram
Please, don't forget Reload the diagram at the end of all actions.
Repository.ReloadDiagram(theDiagram.DiagramID)
Example: This script is located in Diagram scripts group.
option explicit
!INC Local Scripts.EAConstants-VBScript
' *********************** > SCRIPT SUMMARY < ************************* 01-DIA-PackageHyperlink
'> Script Name: 01-DIA-PackageHyperlink
'> Author: Roman Kazicka
'> Purpose: Better navigation in model repository via diagrams
'> the goal is to automatically generate hyperlink to package on current diagram
'> Category: Model Navigation
'> Description: Create on visible Diagram 'PackageHyperlink' to current Package in 'Project Browser'
'> Trigger: Via context menu in current diagram
'> Input: Selected Package in ProjectBrowser, Open diagram on which will be created hyperlink
'> Output: Package hyperling on current diagram with note #ModelNavigation#
'> Date: 20181007
'> Notes:
' TODO 1:
'__________________________> Script Summary < ____________________________01-DIA-PackageHyperlink
' Script Name: 01-DIA-Package Hyperlink
' Author: Roman Kazicka
' Purpose: Better navigation in the model via diagram Package Hyperlink
' Description:
' Trigger: via script in Diagram, (the same thing can be done via Project Browser script with the same name 01-PB-PackageLink
' Date: 2081006
' Diagram Script main function
sub OnDiagramScript()
dim currentDiagram as EA.Diagram
set currentDiagram = Repository.GetCurrentDiagram()
' This check is valuable in run mode
' Diagram have to visible
if not currentDiagram is nothing then
dim thePackage as EA.Package;
dim newHyperlinkel as EA.Element;
set thePackage= Repository.GetTreeSelectedPackage()
set newHyperlinkel = thePackage.Elements.AddNew("$package://"& thePackage.PackageGUID , "Text")
newHyperlinkel.Update()
newHyperlinkel.Subtype = 19 '// This one is important for hyperlinks to packages!!
newHyperlinkel.Notes = "#ModelNavigation#"
newHyperlinkel.Alias=thePackage.Name
AddElementToDiagram newHyperlinkel, currentDiagram
currentDiagram.Update()
'If diagram is not visibe -
else
Session.Prompt "This script requires a diagram to be visible", promptOK
end if
end sub
sub AddElementToDiagram(theElement, theDiagram)
dim diagramObjects as EA.Collection
dim obj as EA.DiagramObject
theDiagram.Update()
set diagramObjects = theDiagram.DiagramObjects
set obj = diagramObjects.AddNew( "l=200;r=400;t=-300;b=-400;", "TEXT" )
set obj = diagramObjects.AddNew( "", "TEXT" )
obj.Update()
obj.Style = "BackColor=-1;BorderColor=255BorderWidth=1;FontColor=-1;VSwimLanes=1;HSwimLanes=1;BorderStyle=0;"
obj.Update()
Session.Output("Added object " & theElement.Name)
end sub
OnDiagramScript
____________________________________
BR
Roman
