Enterprise Architect => Suggestions and Requests => Topic started by: jörg on October 09, 2018, 07:30:47 pm
For using diagrams in requirements engineering, it is needed to have at least a status property and tagged values in diagrams, as they are available in elements.
Maybe is should be possible to add an element reference to a diagram as packages have it (EA.Package.Element). In my opinion this can solve the problem since all element properties will be available to a diagram too, then and it should be able to do that without a database change (adding diagram to the t_object table).
Maybe there are more requirements engineers that have an opinion about that theme?
+1 because I miss that feature e.g. to state if a diagram was already reviewed or not.
+1 from me as well.
There all kinds of reasons to attach TVs to a diagram , for example, to remember its status (reviewed etc) so @Sparx this would be a great feature. Can't see a simple place to put them:
- t_objectproperties looks to have secondary key of the Object_ID, which would get confused with diagram_ID.
- t_xref - where all the strange new stuff seems to go...
Or
- t_diagramlinks - at least this will get tidied-up when the diagram gets deleted, but I've just tried this approach, and any new t_diagramlink rows don't get exported when we XMI the diagram.
- create an invisible element in the diagram, and give the TVs to that? Horrible :-(
Any requirement for this should probably include the ability to move the diagram between repositories.
Any more suggestions for how to do this?
There also seems to be somewhere in the XMI format where this data might fit, if @Sparx were to create a solution for us.
<diagrams> seem to have an <extendedProperties> tag, which is used by elements, but not by diagrams (at least in my examples) so there is a possibility that this might be used to hold diagram tagged values.
Needs a Sparx implementation though...
There is actually a table called t_taggedValue table that is used for parameter tags and connector role tags.
They should be able to use it for diagram tags as well.
...never noticed that table before...
Looks like it's keyed on a GUID, so should do the job OK.
I guess we will have to do our own tidy-up, to delete entries here when a diagram gets deleted, but I'll give this a try.
I still that that the right way to do this is for @Sparx to deliver a solid solution.
I too would like tagged values directly on a diagram.
In the meantime, there is a rather ugly workaround.
- Drag a diagram as a Diagram Frame onto another diagram
- Move this Diagram Frame to the same package as the Diagram
- Make the diagram a child element of the Diagram Frame
Diagram Frames can have Tagged Values just like another elements, and of course you can use relationships to / from (for example realisation of Requirements)
Just a thought
Phil
