Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: AjithPadman on November 23, 2018, 01:53:25 am
I would like to create Template binding connection and the corresponding parameter Substitution specification of a large set of Classes with the Java Script based EA automation. I am able to successfully create a connector using the Element.Connectors.Addnew(""."Templatebinding") api. But I am not able to add the Formal and Actual Parameters to the connector using any automation methods. I found that there is a Templatebindings Collection on a connector class. But This seems to be marked Read only and not able to update this collection. Does anybody know there is a possibility to create the templateBinding objects with definition for the Formal and actual and add it to the TemplateBinding Connector?
To add stuff to EA.collections you have to use AddNew() (as you already did by adding a new connector)
I've never use TemplateBindings before, but if there's a collection then you should be able to add new elements to it.
I did the below code
var connection = currentElement.Connectors.AddNew("TemplateBinding","TemplateBinding");
Session.Output(connection.Name);
connection.SupplierID = el.ElementID;
var tempbinding = connection.TemplateBindings.AddNew("TemplateBindings",el.ElementGUID);
tempbinding.FormalName = "ReturnType";
tempbinding.ActualName = "Test";
tempbinding.Update();
connection.TemplateBindings.Refresh();
connection.Update();
el.Update();
currentElement.Connectors.Refresh();
currentElement.Update();
But this code does not seems to update the parameters substitution. Also I see the templatebinding Collection marked readOnly in the Connector Class Specification.
Just as a guess. First create the connector and update it.
Then do the other stuff with adding the tempBinding.
:)Thanks a lot that worked well
All EA.Collections in the API are marked readonly.
That only means that you cannot set it
something like
thisElement.Attributes = otherElement.Attributes;
Is not allowed (and will return a compiler error depending on the language used)
