Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: g.makulik on May 17, 2012, 10:27:54 pm
What exact syntax is needed to create a connector in transformation IL?
I have written an AddIn that generates the transformation IL bypassing any transformation templates besides 'File', in this template I'm just calling my function from the AddIn using the %EXEC_ADDIN()% macro to generate the IL.
I'm going to transform a StateMachine to a corresponding class model. Here's a simple example:
(http://img849.imageshack.us/img849/7734/simplestatemachine.png)
The states should be transformed to corresponding classes (which works fine), the transition connector should be transformed to a Dependency between the transformed classes. Here is the transformation IL I'm generating for this:
Class
name = "StateMachine"
language = "C++"
Class
name = "State1"
language = "C++"
XRef
source = "{3DC70348-DDA2-40fd-8C97-47FA5AAFF070}"
Dependency
source
XRef
target
XRef
source = "{FB4CF134-EBFD-412e-AE83-63EB2DB5E5DA}"
Class
name = "State2"
language = "C++"
XRef
Dependency
source
XRef
target
XRef
But the Dependency connector isn't generated in the result :( :
(http://img195.imageshack.us/img195/1615/simplestatemachinetrans.png)
What am I missing??
Edit:
BTW, specifying name and namespace properties in the XRef elements doesn't help.
Günther
Well, if I was doing it in the templates I'd have
Class templateClass
TRANSFORM_REFERENCE("Class");
name=%qt%%className%%qt%
language="C++"
%list="Connector" @separator="\n"%
Connector templateDependency
%TRANSFORM_REFERENCE("Connector",connectorGUID)%
Source
%TRANSFORM_REFERENCE("Class",connectorSourceGUID)%
Target
%TRANSFORM_REFERENCE("Class",connectorDestGUID)%
Look at what that generates and see what you get.
OK, think I found out myself. Seems that name and namespace properties in the XRef ARE relevant. Also added an XRef to the connector descriptions. Here's the IL code that works as I'm expecting (not sure if the connector direction property is really relevant somehow):
Class
language = "C++"
Class
name = "State1"
language = "C++"
XRef
namespace = "C++STTCL"
name = "State"
Dependency
direction = "Source -> Destination"
XRef
name = "Connector"
source = "{8E672976-9E34-4164-BA1D-19DB57986542}"
source
XRef
name = "State"
target
XRef
name = "State"
Class
name = "State2"
language = "C++"
XRef
name = "State"
Dependency
XRef
name = "Connector"
source
XRef
name = "State"
target
XRef
name = "State"
Thx to anyone who took the time reading this.
Günther
Thanks for your answer Simon, seems we just posted at the same time.
Yes, that was more or less what I did. I've set up a simple example and used the C# standard transformation to inspect the IL output in detail.
WBR
Günther
