Enterprise Architect => General Board => Topic started by: dry on September 25, 2019, 10:51:10 am
I thought to insert a custom table, for a quick spreadsheet like ..
But I cannot, at all, change the font size inside it - i.e. in the table itself. It stays lookslike at default 8.
I tried setting Default Appearance Font Size, set to 14 - nothing. It does not only not change the font in cells, it doesn't change the heading/name size (element name).
Even when I try print it to PDF, the font size is still small, and if I try to zoom in, it blurs to a bad quality .
How do yo do it ??
I suppose it is like the Model Views: the font is fixed and you can't change it (by now)
I'm not sure what you mean.
But on a model graph / view, I can, usually , change the font - through default appearance - of any element and individually too.
For example, say a (text) Note element. I can change its default appearance's font, which then changes the font the text is displayed inside that Note, on the model view/graph.
