Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: jmcdonnell on August 14, 2012, 01:06:01 am
Hi all,
I want to use two templates in my document generation and I'm aware that this can be done using the virtual documents feature.
After reading the help files I see that a certain template style can be specified to chosen packages for inclusion in report generation.
However, I want to be able to mix report templates in the same document dependent upon element type.
Can anybody recommend how I might go about this?
Thanks in advance,
Joe
The only way to mix templates currently is to create a master document and each virtual document within that can use a different template.
To use a different template for each element from there you'll need to make virtual documents run on searches based on element type.
Another option; If you are interested in using the Automation Interface you can use the Document Generator class to run different templates based on each element you parse.
See: http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/automation/document_generator_interface_class.html
