Enterprise Architect => Suggestions and Requests => Topic started by: wivel on January 09, 2020, 01:04:31 am
In EA 15.1 I would like to see support for translation of/support for multiple languages for linked documents.
Suggestion: Having a linked document, per language you have specified in your project options.
- When adding a Linked Document to your element, you also have to choose the language of the document,from the list of languages you have specified.
- When editing a linked document, you will be presented with a list of already added documents + its language
When deleting linked documents, you should be given the list of linked documents, one per language, if any, to choose from before deleting it.
- It should be possible to specify if the linked document is translated manually or automatically
Generating documentation:
- The Linked Document of the chosen language, when generating documentation, should be included in the generated result
- If there is no linked document for the selected language, it should be possible to specify if the default language should be used, or if no linked document should be included
Has been reported
