Pro Cloud Server / Prolaborate / WebEA => PCS Suggestions and Requests => Topic started by: RuneRaknes on January 17, 2020, 11:14:04 pm
We have defined searches to document and verify elements. An example search is all Business Objects and what application components are using the Business Objects.
These lists are useful for end-users without access to EA and we would therefore like to give the end-users access to the searches on the webEA-portal.
Might be several possible technical implementations to cover this need, the most obvious would be to enable the run of a search from webEA. Maybe a workaround to include a search in a "virtual document" and publish this on webEA?
Any suggestions?
Hello
I agree with you, I think it's a shame not to have the capability to execute the queries of my searches in WebEA.
In general we use a query when the information is found in several diagrams or if we want to do research on specific tags... It's very usefull.
I suggest adding this capability to WebEA. Thanks
Pierre
Running a query on HTML output? I'm not a real friend of Sparx, but being in their place I'd simply say: how? Jquery or such (I don't think it's meant for that, but anyhow)?
WebEA is not the static HTML output, but a web-app connected to the cloud server.
SQL Searches should be very much possible.
Uh, oh. My bad. I shouldn't poke in areas where I have no idea of. Thanks, Geert.
Thank you for all responses. Due to the limitations of webEA we are looking into the use of Prolaborate
Please feel free to reach out to us if you have any questions.
Visit the Sparx Prolaborate website to try it out.
https://prolaborate.sparxsystems.com/
