Enterprise Architect => Bugs and Issues => Topic started by: Prostomax on January 28, 2020, 09:17:20 pm
When using 'Import DB schema from ODBC...' and connecting to PostgreSQL 12.0, EA can read list of DB schemas fine, but when starting import of actual tables EA fails with message "Error retrieving table list!". PG logs says the following:
2020-01-28 11:58:41.925 EET [15312] ERROR: column reference "oid" is ambiguous at character 861
2020-01-28 11:58:41.925 EET [15312] STATEMENT: SELECT
n.nspname AS ObjectSchema, --1
c.relname AS ObjectName, --2
CASE
WHEN c.relkind = 'r' THEN 'TABLE'
WHEN c.relkind = 'v' THEN 'VIEW'
WHEN c.relkind = 'S' THEN 'SEQUENCE'
END AS ObjectType, --3
COALESCE(OBJ_DESCRIPTION(c.oid),'') AS Remarks, --4
COALESCE('TABLESPACE=' || t.spcname || ';','') AS Properties --5
FROM
(SELECT *, oid
FROM pg_class
WHERE relkind IN ('r')
) c
INNER JOIN
(SELECT *, oid
FROM pg_namespace
WHERE nspname IN ('myschema') AND nspname NOT IN ('pg_toast','pg_catalog','information_schema') --WHERE nspname NOT IN ('information_schema','pg_catalog','pg_toast')
) n
ON c.relnamespace = n.oid
LEFT JOIN
pg_tablespace t
ON
c.reltablespace = t.oid
Order By n.nspname, c.relkind, c.relname
ODBC driver version is psqlodbc_12_00_0000.
Please note that import of PG 10 tables in the same EA version on the same PC works with no issues.
You should send a bug report (link below in the Support section). Good luck with that.
