Enterprise Architect => General Board => Topic started by: YanDJ on March 31, 2020, 02:03:51 am
I generate automaticaly ours design with EA and an SQL Fragment.
I am able to retrieve an list of tag value with the same name and rename as "dependencies" with the following code:
GROUP_CONCAT( DISTINCT optag4.value ORDER BY optag4.ElementID DESC SEPARATOR ', ') AS dependencies,
But the query works well but when I have too many characters (> 1024 char) the GROUP_CONCAT stop concat all my tag value with the same name.
I found that in mySQL, I have to write in my query :
SET SESSION group_concat_max_len = 1000000;
But when I try to set, the querry do nothing and return nothing.
Has anyone ever had this problem before?
Thank You
Yan
EDIT: The subject have been resolved by changing the configuration of the server :
I've changed the file "my.ini" in the repository C:\ProgramData\MySQL\MySQL Server 8.0
To add the line :
group_concat_max_len=25000
You will need to execute that in the MySQL admin console (or whatever it's called). EA won't execute it for you.
Ok thank you for the informations Eve, we will try to change it in ours server.
Yan
Have you tried creating a MySQL store procedure or, even better, a view and calling it from Sparx?
