Enterprise Architect => Bugs and Issues => Topic started by: flexjoly on June 13, 2020, 05:52:07 am
Title: Php namespaces not recognized?
Post by: flexjoly on June 13, 2020, 05:52:07 am
Lately I started to work more actively with namespaces in php. I expected that EA would love that and would recognize the connection between classes even beter. But the opposite seems to be true :-(
Because of namespaces it is possible to have the same classnames. But EA does not recognize (nor generate) the correct namespace-path. And EA seems to have never heard of namespaces aliases  :-[
I set some packages as root namespace:
Some of the classes I have are:
Base Data class
<?phpnamespace rh\data\data;class Data implements DataInterface{}?>
Config Data class
<?phpnamespace rh\config\db;use rh\data\listdata\ListAbstract;class Data extends ListAbstract{}?>
A Class which extends the base Data class
<?phpnamespace ls\api;use rh\data\data\Data;class Params extends Data{}?>
The class are imported as by directories and the packages are created on namespaces.
But a class like Params is connected to the Config-Data class and not to rh\data\data\Data  :o :-\
And when looking into the relations or find-window only classnames without their namespaces are shown.
I tried to change the extend to:
  • use rh\data\data and ... extends data\Data
  • extends \rh\data\data\Data
I searched and read many pages in the tutorials. Downloaded the latest version 15.2 beta.
I also tried:
  • setting an alias in the class-element properties[/font]
  • deleted the generated connector (but it comes back after source-synchronisation)[/font]
  • drawing the generalize connector between Params and data\Data  >> source-generation just makes php to multi-extend ;D
What am I doing wrong??? What can I do to get EA to recognize the namespace paths and make the right connections.
And what about namespace aliases? I use "use my\namespaced\Class as Base;" a lot.... but EA just connects to the first "class Base{}" it finds  :-[
I hope someone can help me.
Thanks in advance.
Flexjoly
