Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: fy1997 on July 01, 2020, 05:25:22 pm
Hi!
I want to use SysML to model a SystemC project. I want to use the SystemC library. How should I import the SystemC library into EA?
Not sure what you're after here.
You can import the source code (sort of), but that will give you a UML representation of the classes in SystemC and that only makes sense if you want to model the source code of your project.
If you're doing SysML, I assume you want to model a higher-level design, where SystemC would be a block. In which case there's no point importing anything, just create the SystemC block and you're done.
So... not sure.
/Uffe
