Enterprise Architect => General Board => Topic started by: Evandro on July 17, 2020, 09:50:18 pm
Hi there, in the EA15 user guideline https://sparxsystems.com/enterprise_architect_user_guide/15.1/team_support/permissionlist.html (https://sparxsystems.com/enterprise_architect_user_guide/15.1/team_support/permissionlist.html) seems that the "Update Elements" permission shall enable/disable the right of the user to create/edit/delete elements, packages AND relationships. However, I made some tests and it seems that I'm able to:
- create a realisation from an unlocked class to a locked interface
- create a realisation from a locked class to a locked interface
- create a realisation from a locked class to an unlocked interface
Is there anything I am missing about this kind of user permission?
That seems to be a bug.
You should only be able to do the first (from an unlocked element to a locked element)
I'm making other tests. Element editing works as it should (I can have a locked element represented in an unlocked diagram, just I cannot edit it), so it's not a matter of wrong permissions. Just seems it does not apply to relationships at all. I'm even able to delete existing relationships of locked elements. Never happened before in EA14. @Geert: do you think this bug might be related to the EA version?
Yes, probably. I remember bumping into that a while ago, while demonstrating the locking mechanism to a client.
Make sure to report a bug the though the official channel: https://www.sparxsystems.com/support/forms/bug_report.html (https://www.sparxsystems.com/support/forms/bug_report.html)
This "feature" was there at least since version 13. In fact, not only it was possible to edit, create or delete relationships but, if I remember correctly, Sparx does/did not audit relationships changes very well.
This is likely to be related to Sparx handling elements and relationships separately when relationships are a specialised type of element.
I agree, this is a bug and should be fixed.
