Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: J.D. Baker on February 12, 2013, 06:43:05 am
Title: Object Required error
Post by: J.D. Baker on February 12, 2013, 06:43:05 am
I'm writing a script that includes the code below.  I sucessfully create the new package and the new use case but the set newElement = currentElement assignments fail with errors like
Object required: 'currentElement.Author.Author'
The content of the currentElement fields looks ok.
Session.Output( "found use case" )
'get the Packages collection for the current package
dim packages as EA.Collection
set packages = thePackage.Packages
'create a new package
dim newPackage as EA.Package
set newPackage = packages.AddNew("PJ" & thePackage.Name , "Package")
newPackage.Update()
Session.Output ( newPackage.Name )
' create use case instance
dim newElement as EA.Element
set newElement = newPackage.Elements.AddNew( thePackage.Name, "UseCase")
newElement.Update()
packages.Refresh()
Session.Output("author is " & currentElement.Author)
Session.Output("newElement " & newElement.Type)
Session.Output("currentElement " & currentElement.Type)
set newElement.Author = currentElement.Author
set newElement.Notes = currentElement.Notes
set newElement.Scenarios = currentElement.Scenarios
set newElement.Diagrams = currentElement.Diagrams
Title: Re: Object Required error
Post by: qwerty on February 12, 2013, 07:07:42 am
Unfortunately you don't tell us where currentElement comes from.
Post by: J.D. Baker on February 12, 2013, 11:13:53 am
here's the entire script
option explicit
!INC Local Scripts.EAConstants-VBScript
' This script is intended to be executed against a single element in the enterprise repository.
' It will create an instance of the classifier, add instances of any related elements and
' create relationships between those instances to reflect the relationships between the classifiers
' e.g. when the selected element is a use case, the script creates a use case instance, copies
' the scenarios and any related rule sets.
' Script Name: UseElement
' Author: J.D. Baker
' Purpose: Use enterprise element in a project
' Date: 10 February 2013
' Project Browser Script main function
sub OnProjectBrowserScript()
' Show the script output window
      Repository.EnsureOutputVisible "Script"
      ' Get the type of element selected in the Project Browser
      dim treeSelectedType
      treeSelectedType = Repository.GetTreeSelectedItemType()
      ' Handling Code: Uncomment any types you wish this script to support
      ' NOTE: You can toggle comments on multiple lines that are currently
      ' selected with [CTRL]+[SHIFT]+[C].
      select case treeSelectedType
'            case otElement
'                  ' Code for when an element is selected
'                  dim theElement as EA.Element
'                  set theElement = Repository.GetTreeSelectedObject()
            case otPackage
                  ' Code for when a package is selected
                  dim thePackage as EA.Package
                  set thePackage = Repository.GetTreeSelectedObject()
' determine whether this is a use case or application package
                  dim theElements as EA.Collection
                  dim currentElement as EA.Element
                  dim i
                  for i = 0 to thePackage.Elements.Count - 1
                        set currentElement = thePackage.Elements.GetAt(i)
                        Session.Output ( "i = " & i)
                        If currentElement.Type = "UseCase" then
'            a. Create an instance of the use case and copy all property data, including structured scenarios
'            d. Place instance elements in the appropriate package of the project model.
'               These include an instance of the use case, and any actors or rule sets associated with the use case.
                              newPackage.Update()
                              newElement.Update()
                              packages.Refresh()
                              'set newElement.ClassifierID = currentElement.ElementID
                              'set newElement.Connectors = currentElement.Connectors
                              set newElement.EmbeddedElements = currentElement.EmbeddedElements
                        Else
                              if currentElement.Type = "Component" then
                                    Session.Output( "found Application" )
                              end if
                        end if
                  next
'            b. Determine if links other than the generalization link to the Enterprise Use case exist.
'            c. For each link, create an instance of the linked element and create a link between the instances to mirror the classifier links.
'            d. Place instance elements in the appropriate package of the project model.  These include an instance of the use case, and any actors or rule sets associated with the use case.
'            case otDiagram
'                  ' Code for when a diagram is selected
'                  dim theDiagram as EA.Diagram
'                  set theDiagram = Repository.GetTreeSelectedObject()
'            case otAttribute
'                  ' Code for when an attribute is selected
'                  dim theAttribute as EA.Attribute
'                  set theAttribute = Repository.GetTreeSelectedObject()
'            case otMethod
'                  ' Code for when a method is selected
'                  dim theMethod as EA.Method
'                  set theMethod = Repository.GetTreeSelectedObject()
            case else
                  ' Error message
                  Session.Prompt "This script does not support items of this type.  Select a package to use in a project.", promptOK
      end select
end sub
Post by: KP on February 12, 2013, 11:33:12 am
Because Author is a simple field not an object, you don't need the 'set' command. Just say
Your next problem will then be the Scenarios, Diagrams and EmbeddedElements collections. You can't (AFAIK) copy a Collection in one go; you will need to loop through them item by item.
