Enterprise Architect => Bugs and Issues => Topic started by: KalpakD on May 16, 2021, 09:25:52 pm
Generated code from "basic python model" the Class A code is:
import ClassC
import ClassB
class ClassA:
classC= ClassC()
classB= ClassB()
def OperationA(ParameterOne : int, ParameterTwo : int) -> int:
pass
def OperationB(ParameterOne : int, ParameterTwo : int) -> int:
pass
The attributes have not generated any code.
Any other setting required?
Hello KalpakD,
To generate Python attributes, you need to assign initial values.
Press Ctrl+5 to open the Feature window, then select the ClassA and enter some value to the Initial field. Then, generate source code again.
Dear Takeshi,
That worked.
But is there a way to do model syntax check before generating code?
