Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: KalpakD on July 14, 2021, 02:36:26 pm
While generating code from Activity diagram, code is generated from an action element.
But if there is an activity element connected to a child diagram, no code is generated for the child diagram.
What could be the reason?
regards,
Only actions create code. You might use the activity as call behavior which is an action classified by an activity.
That means the activity diagrams will be huge.
How about the conditional nodes?
thanks,
thanks,
If I understand what you're saying, the diagrams will be the same size. Activities don't appear on Activity diagrams, so replace each Activity with a CallBehaviorAction that links to it (right-click > Advanced > Convert to Invocation)
But now I don't see add a child diagram, only child element, e.g. Expansion node.
Whereas, in a child diagram there can be a full blown sub routine.
regards,
The purpose of purchasing the "unified" version of EA over "professional" was to get activity diagram coding.
But there seems to some limitations or "gotchas"!
regards,
UML is not about diagraming. A diagram is what makes a model readable to humans. The value is in the model.
regards,
Indeed, documentation is for humans. and I think UML is a great way to do it.
This thread is all about generating code.
To make just "pretty pictures" I have been using flowchart and then UML tools for nearly 2 decades.
I want to move onto generating the code also.
Just for documentation, there are far cheaper tools available.
Besides free tools, Visual Paradigm has a far more user friendly UI/ UX.
But it can only do upto generating code for a class diagram.
That is far simpler than code for operations (methods).
regards,
Where are you looking? You don't add the child diagram to the action. You have an activity that defines the sub-routine on its composite diagram, and a call behavior action calls the activity.
Of course action cannot have a sub diagram.
I was referring to the sub diagram connected to an activity element.
Pl see my OP.
Not clear why do I again need a composite sub diagram for an activity element; a sub activity diagram should be sufficient. It is just for encapsulation of a chunk of actions related to one another.
E.g. check an opened file for a set of errors.
thanks,
Same thing
Same thing
The way I am doing it right is put in an activity element and right clicking to select a child diagram.
Is that the correct way?
