Enterprise Architect => Bugs and Issues => Topic started by: ama on September 30, 2021, 12:50:12 am
When an Element is added to a Diagram (e.g. a Business Actor in an ArchiMate Organization diagram), accessing Properties / General the value for Language is Java, rather than <none>.
I don't see why Java should be the default for any newly created Elements.
Go to Configure/Model/Options/Source.../Default Language
That's where you set the language default. Obvious, isn't it? ;-)
Hi
thank you!
Yes, correct, selecting a different language is possible.
Still, having Java as a default in a new project sounds just arbitrary.
You can change that too. EA copies EABase.eap from the program directory. You can replace this with one containing your settings and you have them when you create a new project.
Cool! That's perfect! Thank you!
