Enterprise Architect => General Board => Topic started by: michagast on October 14, 2021, 08:09:50 pm
Hi everyone,
For a university assignment I am currently using Enterprise architect to perform architecture recovery on open source products. I am trying to isolate the most important modules in the products and to do this I want to filter out all classes that either have no relationships or less relationships than a certain amount. I have not found a filter to do this however. Does this functionality even exist within Enterprise architect and if so how can it be done? Thanks in advance for the answers!
Micha
You can join t_object.object_id with t_connector.start_object_id and return the counts. Running that query will return you the number of connectors per element.
Thanks for the quick answer! I cannot find the place to input custom sql queries however. According to the documentation the place should be design-->editors-->Properties dialog. But its not there. Also, will this then allow me to filter out all elements that have less than this connector amount? Maybe relevant information is that i am using a trial version, is this functionality not present in the trial version?
Micha
You can create custom SQLs and in the SQL scratch you can test arbitrary ones. Ctrl-F/Icon left of the red X/SQL Scratch Pad (a bid har to find, but that's EA).
Enter something like SELECT t_object.name, count(*) from t_object inner join t_connector on t_connector.Start_Object_ID = t_object.Object_ID where t_object.Object_Type = "Object" group by t_object.Object_ID, t_object.Name
That will give you all elements with their connector count > 0. You need another one for the orphans. I leave that for you.
I managed to get the query working, thanks! Is there now any way to apply this query as a filter on the diagram? E.g. display only those elements that >0 connections?
Can't help with that. I'm just not using most of EA's gimmicks since they tend to simply not work in more cases than I would like.
Thanks for your help though. Does anyone else know how to achieve this?
