Enterprise Architect => General Board => Topic started by: Mintra on March 17, 2022, 03:09:05 am
Title: Users Auditing - last login
Post by: Mintra on March 17, 2022, 03:09:05 am
version Sparx 15.2
How can I identify the last login date for each user?
Thanks!
Mintra
Title: Re: Users Auditing - last login
Post by: qwerty on March 17, 2022, 03:36:00 am
You can't. And why would you? If you have a license server see when the last one was obtained. (Though I have no idea how to pull that out there.)
Post by: Mintra on March 17, 2022, 03:56:06 am
We have a limited number of licenses and need to reassign the license key to whoever is not using it.
Post by: Modesto Vega on March 17, 2022, 04:02:49 am
Are you using floating licenses? If you are using floating licenses you should not have to face that problem very often.
Post by: Mintra on March 17, 2022, 04:42:20 am
No. I will look into it. Thank you!
Post by: Mintra on March 17, 2022, 05:07:50 am
Hi Modesto Vega,
Do you happen to know where is the user guide for the floating licenses?
Post by: Modesto Vega on March 17, 2022, 05:13:21 am
The easiest way to find which type of licenses are used is to run Sparx EA, go to Help menu in the Start ribbon, and select Register and Manage Your License Key(s).
If they are Shared Keys you are already using floating licenses, if they are not Shared Keys you may be able to reallocate by removing/realising the key.
Post by: Takeshi K on March 17, 2022, 11:22:55 am
Hello all,
Just for your information, using 1 standard (fixed) license among 2 or more users is prohibited by the EULA, even if you remove a license from your machine when you do not use the license.
