Enterprise Architect => General Board => Topic started by: jespergain on March 30, 2022, 05:56:35 pm
Hi all,
I was wondering if it is possible to inherit attributes from other classes and use these inherited attributes for source code generation.
I am fairly new to Enterprise Architect and just started to develop a custom code template for the IEC-61131-3/Structured Text language.
The custom code template works pretty fine already, but I can't figure out how to list inherited attributes from other classes.
I already investigated the Linked Attribute Template from other code templates but can't get the results I hoped for.
An example below:
Class A: Class B:
AttClassA1 AttClassB1
AttClassA2 AttClassB2
Class B inherits from Class A
Now I want to generate code of Class B containing all attributes listed above (so AttClassA1/A2/B1/B2)
Therefore, my question is as follows: Is it possible to list inherited attributes from another class and if so, how can I do this?
Is there a special syntax(code/macro/other templates) that I can use in the Code Template Editor?
I hope my question is clear enough for you all and I am looking forward to your reply!
Kind Regards,
Jesper
If the classes are related, for example through a generalization/specialisation, you can display inherited attributes - please see https://sparxsystems.com/enterprise_architect_user_guide/15.2/modeling/displayinginheritedattribute.html#:~:text=Enable%20Display%20of%20Inherited%20Attributes,%27Override%20Attribute%20Initializers%27%20dialog - and set values.
I cannot answer the code generation question but I would expect it should be possible.
Hello Modesto,
Thanks for your response.
The classes are indeed related trough generalization. I already discovered that you could display inherited attributes but didn't know you could also set other values to these attributes. That is also very helpful so thank you very much.
I also suspect that there is a possibility to generate the inherited attributes to code but can't seem to find how/where. Anyone else got any idea?
Thanks in advance!
