Enterprise Architect => Uml Process => Topic started by: YaronS on April 21, 2022, 06:21:06 am
Title: Behavior of CallBehavior action: under "Element" vs under "Behavior"
Post by: YaronS on April 21, 2022, 06:21:06 am
[Accidentally posted in Bugs & Issues, removed from there and posting here]
For a CallBehavior Action: In the Properties portal, a Behavior can be specified for the Action element under the "Element" tab and/or under the "Behavior" tab.
And they are not coordinated with each other - i.e., say, if I enter a behavior in the Element tab, it won't also show up in the Behavior tab, and vice versa.
What is the difference between the two?
Thanks!
Title: Re: Behavior of CallBehavior action: under "Element" vs under "Behavior"
Post by: qwerty on April 21, 2022, 05:58:17 pm
I would guess that only a Sparxian will know the answer. You can mail to their support where they are very responsive. The forum became a bit silent Sparxian-wise.
Post by: YaronS on April 22, 2022, 07:49:07 am
Thanks, I'll try.
A similar one that I see: On a Control Flow, for a flow guard, there's a Guard property under "Connector" as well as under "Constraints". But it shows up as a guard label in the diagram if I put it in "Constraints".
That's unfortunate...
