Enterprise Architect => General Board => Topic started by: Wishmaster84 on May 06, 2022, 07:57:26 pm
Title: Relationship Matrix and Properties
Post by: Wishmaster84 on May 06, 2022, 07:57:26 pm
I would like to produce a relationship matrix where the target will be a list of properties (SysML) contained in several Internal Block Diagrams. My purpose is to show on the matrix only the properties of one type.
Is there any option to do this?
Title: Re: Relationship Matrix and Properties
Post by: Geert Bellekens on May 06, 2022, 08:01:13 pm
Things are not contained in diagrams. They are contained in elements and packages.
When you select a target package, you should be able to limit the types shown using the dropdown.
You could also use a search, but IIRC that has to be a hardcoded search (no way to enter a search parameter or context package)
Post by: Takeshi K on May 09, 2022, 07:52:16 am
Just for your information, our Traceability Suite Add-In supports a matrix between Properties and IBDs. But usually, by specifying Blocks as Source and IBDs as Target, you can find which IBDs contain Properties typed by the Blocks.
https://www.sparxsystems.jp/en/trace/
