Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Helmut Ortmann on June 23, 2022, 09:51:17 pm
If I use a query with the Search Window I get an EA TIMEOUT error after around 30 seconds.
If I use the C#/VB API I get after around 30 seconds an empty result. No indication of an error except the empty result occurs.
Can and how can I modify the TIMEOUT time?
Thanks and best regards,
Helmut
Hi Helmut.
Which version of EA and PCS are you running? In the later versions of EA 15.2 and PCS 4.2x, (cant remember the actual build numbers) there is an option in EA to set at timeout value. Its located at Configure -> Options -> Cloud -> Maximum Query Time.
Hope this helps.
Henrik
Hi Henrik,
I've found it:
Helmut
