Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: MarcinG on January 05, 2023, 02:25:24 am
Title: EA 16 build 160X and DOORS add-in 3.0.3xxx
Post by: MarcinG on January 05, 2023, 02:25:24 am
anyone installed/enabled DOORS add-in successfully ?  It is not appearing in Add-in window, and it seems that it gets installed on the path used by 32 bit software (C:\Program Files (x86)), while EA 16 gets installed into the other location (C:\Program Files).
Any help would be appreciated.
Best regards
Marcin
Title: Re: EA 16 build 160X and DOORS add-in 3.0.3xxx
Post by: Paolo F Cantoni on January 09, 2023, 04:27:58 pm
did anyone install/enabled the DOORS add-in successfully?  It does not appear in the Add-in window, and it seems that it gets installed on the path used by 32-bit software (C:\Program Files (x86)), while EA 16 gets installed into the other location (C:\Program Files).
Best regards
Marcin
Hi Marcin,
If you are using the 64-bit EA (which you seem to be from the path), then the 32-bit Add-In won't be visible.  I have the same problem with my own Add-In, which is still only 32-bit.
Try installing the 32-bit v16 EA, and it should then appear.
