Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Ribeye on March 20, 2023, 03:42:28 am
We need to find elements in our model by the value of Tags. Foreign keys to external systems, for example.
This seems like a common requirement and we are new to EA SQL.
Can someone point to or provide a snippet of SQL that will do this?
Thanks in advance.
Try
SELECT * FROM t_objectproperties WHERE object_id = <the element id>
Depending on the mix of MDGs you are using you might need additional info from t_xref, but give the above a try first.
