Enterprise Architect => Bugs and Issues => Topic started by: Modesto Vega on May 31, 2023, 12:49:52 am
Title: Pasting a diagram with legends using Shallow type
Post by: Modesto Vega on May 31, 2023, 12:49:52 am
Another issue with legends. Just noticed that when copying a diagram as pasting it as new diagram with a "Shallow - Links to exiting elements only"  type, legends are copied. This makes legend reuse difficult and cumbersome.
Why aren't legends treated as if they were another diagram element?
We are using v16.1.1621 64-bit with a SQL Server backend.
Title: Re: Pasting a diagram with legends using Shallow type
Post by: Geert Bellekens on May 31, 2023, 01:20:42 am
Exactly!
For one client I had to write a cleanup script just to get rid of all the duplicate legends.
Post by: Paolo F Cantoni on May 31, 2023, 08:27:31 am
Exactly!
For one client, I had to write a cleanup script just to get rid of all the duplicate legends.
Modesto, it has always been so.  This is another manifestation on the diagram "owning" certain types of elements.  I'm not familiar enough with the depths of the UML spec to determine if this is a UML requirement or merely a "Sparxian" decision.  In either event, I believe it is spurious.  In the case of relationships, there is a setting to override the "strict" UML behaviour.  There should be something similar for these elements.
In our view, the only element that should be unique to a diagram is the Title Block (incorrectly referred to as the DiagramNote Element).  If the user is making a shallow copy, by definition, they want links, not instances.
Like Geert, we've had to write automata to clean up the duplicates and point all references to the "template" instances of Legends, Notes, Texts etc...
Post by: BobM on May 31, 2023, 04:10:11 pm
I had reported this legends bug in v16.1.1621.64bit on 1st of december 2022
Thanks for contacting Sparx support.
We appreciate your findings. The issue you highlighted has been reported to the appropriate team and is confirmed as an issue. This will be addressed in the future releases.
In 16.1.1623 release notes:
Ensure Diagram Legend objects are not duplicated with a Shallow Diagram copy or Diagram Clone
Post by: Geert Bellekens on May 31, 2023, 04:11:38 pm
So it should be fixed now? nice :)
Post by: BobM on May 31, 2023, 04:13:54 pm
It has been fixed on Januari 17th 2023
I think it was a complete fix as I heard no more complaints about it after we installed that update.
Post by: Modesto Vega on May 31, 2023, 07:00:04 pm
Thank you Gert and Bob, I guess it is time to upgrade to v16.1 (Build 1625), the latest.
I am hoping Sparx Systems doesn't make another release soon, our service desk is never happy with frequent upgrades.
Paolo, since they fixed the issue; it must be a bug and does not have anything to do with strict UML behaviour.
Post by: Geert Bellekens on May 31, 2023, 07:05:38 pm
On the contrary for me. I'm still waiting for the bugfix to make document generation work again as it was in v15.2
I have several clients who are stuck on v15 because of this bug in v16.
I had a few encouraging conversations with Sparx about this, but it has been all crickets and tumbleweeds for the last couple of months.
Makes me afraid they are working on v16.5 or v17 or something like that and no longer focussing on fixing regression bugs in v16.
Post by: Modesto Vega on May 31, 2023, 07:21:32 pm
Can you please remind me what the documentation issue is?
Hopefully, Sparx has not accidentally reversed the preference mentioned here, https://sparxsystems.com/forums/smf/index.php/topic,47671.0.html, in Build 1625.
If they have, upgrading to Build 1625 is not an option.
Post by: BobM on May 31, 2023, 07:22:19 pm
As I'm waiting for some mayor and minor bug fixes as well, I marked 9th of June as a potential release date for a new version, if it isn't then there might be no releases until 16.2 which is predict will be released right after global summit (in September?).
Post by: Geert Bellekens on May 31, 2023, 09:17:05 pm
https://sparxsystems.com/forums/smf/index.php/topic,47342.msg276026.html#msg276026 (https://sparxsystems.com/forums/smf/index.php/topic,47342.msg276026.html#msg276026)
Post by: Paolo F Cantoni on May 31, 2023, 09:50:31 pm
Paolo, since they fixed the issue, it must be a bug and does not have anything to do with strict UML behaviour.
With respect Modesto,
My suspicion is that Sparx made Legends "the exception that proves the rule".
When I said it's always been so, we ran the tests as soon as Legends were created and Legends fitted the "Bjelke-Petersen Test - If it walks like a duck and it quacks like a duck, it'll get shot like a duck!  My word it will".  It never occurred to us that Legends should be different to the other Text elements - which, as I mentioned, we believed shouldn't be cloned.
It's good that it's been fixed, although we don't care anymore as we have to manage a pile of other item metatypes in the same way.
Post by: Modesto Vega on June 01, 2023, 12:29:44 am
Paolo, fully appreciate where you are coming from, it is not easy to manage upgrades of large repository with legacy content and customisations.
[SNIP]
Have you considered the possibility that Sparx Systems made it look and quack like a duck, until they realised it actually wasn't a duck?
Post by: BobM on June 14, 2023, 06:18:31 pm
Hi Geert,
I noticed a lot of entries on document generation on the 1626 release
Have all issues been handled "properly"?
Post by: Geert Bellekens on June 14, 2023, 07:26:56 pm
I wouldn't know. I had no idea there was a 1626 .
I do keep an eye on the latest news forum, but it seems they forgot to publish it there. https://sparxsystems.com/forums/smf/index.php/board,22.0.html (https://sparxsystems.com/forums/smf/index.php/board,22.0.html)
(oh, I see, its only just released today)
I'll let you know as soon as I'm able to test it. It sure looks promising.
Post by: Eve on June 15, 2023, 08:05:16 am
The process is now that the forum announcement is intentionally made the day after, so you should see an announcement later today.
Post by: BobM on June 23, 2023, 12:55:30 am
Some small feedback on testing on the latest Procloud and latest Sparx.
Yes its improved, and some really unappealing stuff is out like:
- Model Roots and Diagrams will now no longer return information about connectors
But for Sparx client with basic tests we have to conclude it still does have some odd behavior;
Considering the community is the QA we will report our findings to Sparx; Perhaps some things are logical.
Eg. A BPMN subprocess activity is not filtered out when you don't want to see activities (which does seems odd to me)
Do note that we had to go trough abnormal methods to find this occurrence, so its definitely not a breaking issue.
Vast improvements nonetheless and for now just minor nuisances were observed.
