Enterprise Architect => Bugs and Issues => Topic started by: StefanFS on June 29, 2023, 10:23:50 pm
Title: Updating dynamic content in custom documents produces extra paragraph marks
Post by: StefanFS on June 29, 2023, 10:23:50 pm
in EA v16.0.1604, I am trying to use the "custom document" feature in order to create an architecture description in MS Word format. I'm using fragment templates to insert dynamic content. Inserting seems to work well. However, when I am using the "update dynamic content" function, EA apparently always duplicates the last character of the template, which normally is the end-of-paragraph mark. With every update, there are additional paragraph marks inserted. In other cases, when the fragment template contains a table, apparently the end-of-table mark is duplicated, such that I get a table in a table after updating the dynamic content, so the format is completely destroyed.
Several questions:
This is a very annoying issue, because the model content is still changing frequently, so frequent document updates are needed. After several such updates, the document becomes unreadable and the only workaround seems to be to remove all dynamic content and re-insert it.
Kind regards,
Stefan
Title: Re: Updating dynamic content in custom documents produces extra paragraph marks
Post by: skiwi on July 06, 2023, 01:27:08 pm
Additional new line characters being added in document generation has been there since day dot.
Some work was done a few years ago to reduce the number, but it was and is an ongoing issue.
For me I see it particularly when placing text in tables.
