Pro Cloud Server / Prolaborate / WebEA => PCS General Board => Topic started by: Mauricio Moya (Arquesoft) on August 03, 2023, 07:45:00 am
According to https://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/vl_config.html about setting up the Visibility Levels, the first thing I have to do is to run some SQL scripts for SQLServer. But... where are those scripts? they are not in the obvious place (https://sparxsystems.com/resources/repositories/index.html), so where are they located? I was looking for them also in the registered user section but they are not there.
Send a bug report. These underlined text should be links.
The files will be installed by the ProCloud installer. See the help page you mentioned.
You are right! I have just checked and they are in the folder: C:\Program Files\Sparx Systems\Pro Cloud Server\VisibilityLevels
