Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: makarandd on April 12, 2004, 10:49:19 pm
Title: Integration between EA and ERWin
Post by: makarandd on April 12, 2004, 10:49:19 pm
There was a post about integrating EA and ERWin. Can anybody please post more details?
Thanks in Advance !
Makarand
Title: Re: Integration between EA and ERWin
Post by: Bruno.Cossi on April 13, 2004, 05:35:47 am
the post you mention could have been mine. We have for our internal project needs developed a tool for conversion of ERWin models into EA and are currently turning the convertor into a standalone tool that should be released shortly.
In the meantime, should you need to convert ERWin models into EA, you can follow these steps:
1. Export ERWin model into Oracle Designer (menu File > Export). Oracle Designer is available free for non-commercial use at www.oracle.com
2. Use our Oracle Designer - EA convertor to convert the ERD from Oracle Designer to EA
Hope this helps!
Bruno
Post by: makarandd on April 13, 2004, 09:47:57 pm
Thanks Bruno !!
Where can I get a copy of the Oracle Designer - EA convertor ? Is http://www.standardcase.com/download/EAPB.zip the tool I need to use ?
Post by: Bruno.Cossi on April 13, 2004, 10:05:33 pm
actually no, that is a tool for reverse engineering of PowerBuilder applications into EA.
The tool you are looking for is here:
www.standardcase.com/download/EAORADES.zip
Prior to running it, you will have to install runtime:
www.standardcase.com/download/PBCLTRT90.zip
Please let me know if you need any assistance!
Bruno
Post by: makarandd on April 15, 2004, 10:05:22 pm
Bruno,
I was happily using your tool when the requirements changed :). Now I need to evaluate if data/logical models in EA can be migrated to ERWin !!! Is there a tool which can do that ? I was thinking of using XMI export and the ERWin All Fusion Component Modeler or XMI export / import to generate a Rose Model first( I think RR has an integration with ERWin).
Bruno/Other modeling Gurus, can you please advice !!!
Thanks !!
Makarand
Post by: Bruno.Cossi on April 15, 2004, 10:35:14 pm
Hi Makarand,
don't you love it when requirements change on you? You may soon find yourself having to integrate EA with Notepad! :-)
The approach you describe should work in theory, ERWin does have import from Rational Rose. There are incompatibilities between EA's and RR's XMI, but you may get lucky.
If it does not work, please do let me know. We have the functionality for a conversion from EA to ERWin (or to Oracle Designer) as well and could make it into a standalone tool if required.
Good luck!
Bruno
Post by: makarandd on April 16, 2004, 10:17:30 pm
Hi Bruno,
EA with notepad :) That would be the day !!!
I tried the EA to RR XMI thing..but it gobbled up some of the associations and links !!
That EA to ERWin tool you were talking about..could I have the URL please  ;D
Thanks !
Makarand
Post by: Bruno.Cossi on April 21, 2004, 09:40:15 pm
Hi Makarand,
I did not see your post until now! I have asked our developers to prepare the tool (we have the functionality as part of a bigger package we use for our internal projects, so we have to make the convertor to be standalone). As we are pretty busy these days, it won't be ready until the next week. Is that ok?
Please e-mail me and we can discuss this in detail.
Bruno
[email protected]
