Enterprise Architect => General Board => Topic started by: EA_enthusiast on December 30, 2023, 03:36:02 am
Hello EA Experts,
I inherited multiple models/files and found that managing/maintaining them separately would be a nightmare. I merged all the models/files into one model/file. Now, I have duplicate elements in the master model. For example:
Class A (instance 1)---> appears 10 times
Class A (instance 2)---> appears 7 times
Class A (instance 3)---> appears 3 times
What is the most effective and efficient way to:
(1) Find the frequencies (number of appearances) of each element (as shown above)
(2) replace Class A (instance 2) and Class A (instance 3) with Class A (instance 1)
Thank you so much!
Probably a query by count for the name would be a way (differs for DB types). You can script replacement. Not impossible but a bit tricky since you have to find and fix the connectors and the appearances in various diagrams.
Thank you, qwerty. I will try that.
There is an IDEA add-on that does deduplication on elements and connectors.
See https://data-docent.nl/ideaen.aspx#gsc.tab=0 (https://data-docent.nl/ideaen.aspx#gsc.tab=0).
See https://data-docent.nl/ideaen.aspx#gsc.tab=0.
Thank you for sharing this. I didn't know about this addon. I'll check it out.
Unless you need to merge all 3 versions of your Class A, if there is an interest in having a view of each version in your repository, you could create a master Class A linked via a dependency (or other link) to each existing Class A element.
Thank you for your response. I don't need to merge all 3 versions of the Class A. If I understand your suggestion correctly, you suggest creating a master "Class A" linked via a dependency to each existing "Class A" element. This suggestion assumes that I have found and identified the duplicate "Class A" elements, which is not the case; it's actually the objective I am trying to achieve.
