Pro Cloud Server / Prolaborate / WebEA => PCS Frequently Asked Questions => Topic started by: ea0522 on February 15, 2024, 09:25:29 pm
Title: Prolaborate Lifecycle Configuration with ArchiMate stereotypes
Post by: ea0522 on February 15, 2024, 09:25:29 pm
Prolaborate has a promising Lifecycle feature (see https://prolaborate.sparxsystems.com/resources/v5/documentation/lifecycle-roadmap (https://prolaborate.sparxsystems.com/resources/v5/documentation/lifecycle-roadmap)).
In that documentation is mentioned as a prerequisite that pre-defined date type tagged values must be included for the required stereotype when defining the modeling language.
Now I have a number of ArchiMate 3.1 WorkPackages containing the information on the projects we are working on.
And I would like to use those default stereotypes for showing a Lifecycle Roadmap.
For that I have defined some date type defined tagged values assigned to the elements but they are not recognised when defining the Lifecycle within Prolaborate.
Is it really necessary to define a custom stereotype for using the Lifecycle feature?
Title: Re: Prolaborate Lifecycle Configuration with ArchiMate stereotypes
Post by: Guillaume on March 08, 2024, 12:12:07 am
I tried the Lifecycle roadmap which I'm confident will be useful for a number of Prolaborate owners.
I reported the same concern to Prolaborate support and I understand it has been identified as a future enhancement.
Post by: ea0522 on March 11, 2024, 05:54:17 pm
Thanks Guillaume for your comments and action taken.
In a later test, it looked like the enum defined Tagged Values are only available when the enumeration values are numerical digits.
Does this sound familiar?
Post by: sjf on July 11, 2024, 11:23:02 pm
I found the same issue, the recommended approach from an EA perspective is to use a dataType with the notes as Type=Date; This works find in EA, however it does not work in Prolaborate, the recommended approach is to use the EA legacy mechanism of creating a tagged value type with the same name as your tagged value and add Type=Date;
 to the detail of the tagged value. This off course means that you have to create lots of tagged value types - one for each unique tagged value name in your MDG.
Post by: zee9x9 on July 25, 2024, 07:50:15 pm
Could you please elaborate more on this topic, as I have used the same approach but it I was not able to produce any results.
Post by: Nabil on August 05, 2024, 07:38:25 pm
Thank you for your request. The enhancement you requested will be delivered in Prolaborate 5.4. For more details on this topic, please send an email to [email protected].
Post by: Greg_PL on February 21, 2025, 10:04:19 pm
Hi. 5.4 up and running, however issue is still in place... Please advice how to show date tagged values in Prolaborate Lifecycle Roadmap.
In my case the Lifecycle Configuration handles the MDG stereotype and TVs, but the dashboard + widget DOES NOT show any stereotypes in the dropdown (after selecting a proper package with proper elements of course).
Has anyone found a solution???
Greg
Post by: Geert Bellekens on February 21, 2025, 10:57:19 pm
How you did you setup the Date type for the tagged values?
Post by: Greg_PL on February 22, 2025, 03:12:15 am
Yes.
Did it in all possible ways: predefined values (only ones working to be shown in Lifecycle Configuration) and as separate DataTypes in MDG (those ones do not even appear in lifecycle configuration).
Post by: Greg_PL on February 22, 2025, 03:17:42 am
And to be more precise:
To make redefined ArchiMate Application Component visible in Prolaborate Lifecycle Configuration I had to extend it to Component metaclass in MDG. If I keep simple <<redefines>> relation do ArchiMate3::ArchiMate_ApplicationComponent Prolaborate does not even list it in available stereotype dropdown... It needs to be extended... I'm not sure if this is the way how I should deal with iy, but apparently simple redefinition does not work i Prolaborate.
