Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Ribeye on March 19, 2024, 08:23:03 pm
Normally I would use Visual Studio IDE to write C# plugins. Works well.
But being behind someone's firewall means I don't have access to Visual Studio IDE. They do have Visual Studio Code.
I see elsewhere https://sparxsystems.com/forums/smf/index.php/topic,46362.msg271355.html#msg271355 it says
"Visual Studio Code does not have a compatible API"
Does anyone have a work around, some way to use Visual Studio Code to write a plugin?
There's a difference between writing C# addins, and using the VS plugin for EA.
In your case (writing C# addins) you simply need to be able to generate a COM compatible C# dll.
You don't need an integration with EA.
I haven't tried Visual Studio code myself, so I can't say for sure whether or not this tool can be used for EA add-ins.
My gut says it should be possible.
Here's some more info on how to use Visual Studio Code for .Net Framework
https://stackoverflow.com/questions/47707095/visual-studio-code-for-net-framework (https://stackoverflow.com/questions/47707095/visual-studio-code-for-net-framework)
It might be easier to convince the powers that be, that you need Visual Studio.
Thanks Geert. "its too hard to use Visual Studio Code" was my conclusion. If you say, it will be so for sure.
Thanks again.
