Enterprise Architect => General Board => Topic started by: Alexander.Golyshkin on May 07, 2024, 01:35:17 am
Title: Export diagram to Plant UML format
Post by: Alexander.Golyshkin on May 07, 2024, 01:35:17 am
Is there possible to save EA created diagrams to plant UML format *.puml?
Title: Re: Export diagram to Plant UML format
Post by: ikuehl on May 07, 2024, 01:47:46 am
Here is documentation how you could generate PlantUML from EA:
https://modelhelper.home.blog/2019/03/10/create-a-sequence-diagram-using-plantuml/.
Ingmar
https://www.kuehl-at.com/ (https://www.kuehl-at.com/)
Post by: mhuebsch on August 21, 2024, 12:53:08 am
Has anyone experimented using this technique for ArchiMate diagrams in EA?
Post by: Sunshine on August 21, 2024, 06:03:29 pm
I've managed to exchange archimate models successfully between Archi and Sparx EA using ArchiMate model exchange format. The only thing that turned out to be an issue is the same element multiple times on the diagram which is not allowed in Sparx EA.
Post by: qwerty on August 22, 2024, 05:34:56 am
Actually creating a script to output a SD as Plantuml is not that difficult. I would guess that within a day you have some rudimentary scaffold. Sure, the details might turn out to be painful. But Pareto still rules.
